Car would not start this past summer... At that I decided to continue gutting the interior, replacing coolant hoses, steering rack boots... things i felt more comfortable with.
This week I decided to tackle the eletrical issues, I was not willing to shell out the few hundred dollars to replace the corroded and cracked wiring harness that connects to the 14 pin connector so I replaced the majority of the wires best I could. I tried starting the car and got the same clicking sound from the fuse panel (same sound I experienced this past summer). I took a closer look at the panel and was going to try testing some of the fuses/relays and looked at XV on the panel for the starter relay and there was no relay, instead a switch is wired up to it, Here a couple pics of the switch and wiring... thoughts?
