928 Forum 1978-1995
Sponsored by: 928 Specialists
Tranny - Diff Fluid Change - Recommendations?
Old Dec 12, 2010 | 03:04 PM
Bernie's Avatar
Bernie
Default Tranny - Diff Fluid Change - Recommendations?
Hey Folks,
Doing a tranny and diff service on my 85 AT today.
Was wondering what brand / type fluids I should pickup and also in what quantities?
TIA for the help.
Cheers
Bernie
Old Dec 12, 2010 | 07:25 PM
blandis's Avatar
blandis
Searched on here and several like Mobil 1 fluid. IIRC dextron III or above is sufficient (may check your manual).
Used it last weekend when I swapped out gasket and filter. Did not drain torque converter. I purchased 4 qts and have more than a half quart left.
Old Dec 12, 2010 | 10:51 PM
Mike LaBranche's Avatar
Mike LaBranche
I've been real happy lately with Redline full synth along with a bottle of atf seal treatment, the diff I use Redline 90. Since you didn't drain the tc the first time around, I'd start over with completely fresh trans fluid.
Old Dec 12, 2010 | 10:57 PM
SeanR's Avatar
SeanR
Red Line from Roger, 75w-90.
Old Dec 12, 2010 | 11:49 PM
Bernie's Avatar
Bernie
Thanx fellas,
Ended up going with a Valvoline full synth. Couldn't find any of the others today and I was in a hurry to get it done.
Do appreciate the responses though!
Cheers
Bernie
Old Dec 13, 2010 | 12:25 AM
Mike LaBranche
Honestly, it doesn't really matter much. The trans will love the fresh fluid, fresh filter, fresh diff lube. Change it out... and then drive the **** out of it.
Old Dec 13, 2010 | 12:32 AM
Speedtoys's Avatar
Speedtoys
Mike:
Dont forget that we discovered that how the fluid tastes, matters too.
