Now another problem :(
I just finished my top end refresh and now in the morning when I run the car for 5-10min to warm up, I get a leak in the rear. It looks to be coming from the Trans. It only leaks in the morning. The rest of the day it's ok. It leaves a 3x3 inch spot?
Any ideas?
Any ideas?
Team Owner
time to get down or up on a lift is better,
its either one of the cooler lines, leaks down the sides of trans
or its the front pump O ring seal or the TC radial seal, leaks out of the grate.
So replace the flex lines if you pull out the trans to replace the O ring and radial seal also replace the TC front support bearings (2)
