European hose clamps
The ABA clamp is referred to as the model S40, or "Original" stainless steel - it is a nicer looking clamp, and the housing is one-piece and slightly more compact. On the other hand, the inside surface of the AWAB housing is shorter, which should help it conform to the hose shape better. Both clamps have excellent holding power.
A quick search turned up the ABA S40 clamps here: http://www.truechoice.com/prodinfo.asp?number=ABA%2012
The ABA original series 316ss are virtually identical to the 304ss. I phased out the 304's because there are more sizes available in 316 (actually, sizes 3, 4, and 6 are only available in 316ss) and with higher nickel content, they polish up nicely. They are also approved for marine applications. The cost differential between 304ss and 316ss was 10-20 cents per clamp.
![](http://www.ultimategarage.com/hardware/aba-304316b.jpg)
Rest in Peace
There's also an assortment kit for the original series.....
![](http://www.ultimategarage.com/hardware/aba316a.jpg)
