So...How is the 928?
#31
Again, thanks for all the great insight
LUCKYJACKASS: I want your car to have my babies. Beautiful
2 seconds of poking around on my local craigslist gave me this:
http://newjersey.craigslist.org/cto/2054566920.html
http://newjersey.craigslist.org/cto/2080118713.html
Didnt see that coming, now thats my kind of prive range!
What kind of work would you say these would need? I love looking at 944's in simillar condition and thinking of everything that could be wrong, but I'm only starting my research on the 928
#32
Team Owner
of the two i would go for the 85 it has a 32V engine and with a bit of work you can add Porkens chips, you should be close to 300HP if you fix all of the other parts. The bad running could be a bad coil wire.
offer 1500. and figure to add about 5K to make it right
#34
#35
I would go with a 16 valve, more economical to repair and keep up, 32 valve engine parts are expensive.
#36
No offense, but I don't believe in "refreshing" or fixing things that aren't broke. Timing belts being an exception obviously. I can do that myself...probably
#37
Well there are some oil breather lines that go under the intake, they get soft and break into pieces when old. To change them you need to take the intake off, when you take the intake off, theres a good chance you have to change your Knock sensor(85,86 have only one but S4 has 2). If the breather lines are fine, I would just leave the intake alone and just do a T-belt replace and fuel line replacement.
I took my intake off because one of the breather lines was shattered.
One thing I would be worried about buying a 928 that was not maintained well is head gasket damage, when the coolant doesn't get changed every 2 years it gets acidic and will soon eat the head gasket, after that it will eat up the head, whats worse is that in some cases the bad coolant will start eating the cylinder walls which translates to needing a new short block.
#40
Here are a few that I would look a bit closer at, even though they are a littele further from you...I am not sure where in Jersey you are. These are low cost and appear to be in better shape than the two you posted earlier. Take a look at tempestsearch, they have added a new auto search site that looks at other auto sales sites now too.
http://cgi.ebay.com/ebaymotors/1984-...item35ae4c3e8e
http://cgi.ebay.com/ebaymotors/Very-...item255f4c6021
http://lancaster.craigslist.org/cto/2062232242.html
http://philadelphia.craigslist.org/cto/2072189901.html
#41
Awesome thanks! I really need a new job, next purchase needs to be an air cooled for my vw daily. I'm so shocked at how low these things are, timing belts and I'm good to go right?
#42
Change all the rubber fuel lines, its as important as changing the T-belt, many 928s have left us by catching on fire. just do a search on fire and you will find many cases.
#43
I would vote for the '84 in Philly if it runs as well as the seller says. Unless the car has been painted, that faded red paint is likely just oxidized and will polish up nicely.
It's hard to tell from your posts, but I hope that you aren't looking for a cheap 928 to be your daily driver.
#44
Water pump too, since it's part of the timing belt circuit. Good belt won't do you any good if the water pump dies.
Personally, I think if you are taking a "fix it when it breaks" approach you would be better off with a 16v (non-interference) motor. That would mean 84 or less. Water pump or timing belt failure on a 32v motor leaves you with a badly damaged engine.
