Mystery valve help
Mystery valve help
This valve has a power and ground wire that were in bad shape so I was replacing them.
PN is partially unreadable. What I can read (sort of) is 280141001 (its Bosch). I tried a 9 in front of it but can't find it in PET or manually in a parts manual.
What does it do, what symptoms would it give you when not working and how do you check if it is working?
I was monkeying around with mine...and when I unpluged it just to see how the car would react, it would idle as if the a/c was not working/engaged....
I was planning to do my own as well as I did not see anything special from a wire or connector perspective.
Thanks all.
Correct Harness $21.
I also ordered two for my own cars.
