87 s4 5 speed cutting out
Team Owner
I think you should go to the beginning and replace the 3 relays for the fuel pump LH, EZK
Also replace the fuel pump fuse and clean the rest of them,
get a fuse relay chart here928GT.com on page 2 under tips and links print one off. Use new relays Roger sells em about 8.00 a piece they are 53 relays
Team Owner
you have not been here long enough to hear Jim Baileys mantra
Relay, Relay, Relay.................followed closely by check your grounds
The CPS has a harness and connector that's also suseptible to [heat damage. Located under the throttle wheel (under airbox) can be a break of the CPS signal.
QUOTE=Mike Frye;8067254]Crank position sensor. It tells the system that the car is cranking. Found on top of the bellhousing under the air filter.[/QUOTE]
RE: Relays
Check for our sponsors and send your business their way
These are the first places to look or at least eliminate as failure points.
RE: Relays
