928 Forum 1978-1995
Sponsored by: 928 Specialists
Door Lock Actuator????
Old 10-30-2010, 03:11 PM
Larry Kohler
Larry Kohler's Avatar
Default Door Lock Actuator????
I am looking for a door lock actuator for my 1986 928S 5 speeed. I have absolutely no idea what the part looks like. Would someone please check eBay #390257164993 and advise whether of not that is the correct actuator for my car? Thanks Much
Old 10-30-2010, 03:43 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,548 Likes on 1,430 Posts
Hi Larry you need to provide more info,
What side of the car is it for?
What is the problem with the old part
Old 10-30-2010, 03:56 PM
Larry Kohler
Hello Mrmerlin, Thanks for your reply. The hell with the part, how about a ride in the P51? ;-) I'd give a reasonably good body part to do so. By way of clarification, that would be a part of my body, not of my 928.
My Porsche mechanic did not tell me that the actuators are handed, I'll have to check to see which side it is. I have been having a problem with the door locks locking and unlocking by themselves continuously. I have been told that this is a common problem with 928s? The mechanic told me that the problem is the door lock actuator. I'm used to working on classic Brit cars, but am a novice with the 928.
Old 10-30-2010, 04:04 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
OK so the door locks are continuously cycling ? this may be an electrical problem with the rearside of the lock cylinder .
the fact that the locks are cycling says the lock actuators are good. The more precise info you can provide the better the diagnosis.
Also what was the last thing you fixed?
did you check the 2 fuses in the fuse holders above the CE panel they have thin red wires with a white stripe if a fuse blows then this may cause the cycling
Sorry I dont have a Mustang to offer rides in.
Quick Reply: Door Lock Actuator????
