928 Forum 1978-1995
Sponsored by: 928 Specialists
Ground question.
Old Oct 23, 2010 | 09:40 PM
Hkp7's Avatar
Hkp7
Default Ground question.
What does the ground inside hatch right rear quarter provide ground to?
Old Oct 23, 2010 | 10:09 PM
Hkp7's Avatar
Hkp7
84s also there is a grommet for side marker wiring missing blowing dirt directly on ground connection.
Old Oct 24, 2010 | 09:47 PM
Hkp7's Avatar
Hkp7
Ok, I removed the ground and connection was filthy. before I removed it, I checked fuel pump ground with a meter and found high resistance, removed ground and still have a reading of the same high resistance. Maybe my ground is grounded. Anyway, this may be the cause of my running rough onder load as in fuel starvation. Who knows, Guess I will see when I go through the harness, repair the fault, and run it again.
