928 Forum 1978-1995
Sponsored by: 928 Specialists
Part Identification help..micro switch
Old Oct 20, 2010 | 09:39 PM
Herman K's Avatar
Herman K
Default Part Identification help..micro switch
What's the function of the micro switch part # 36 on the clutch pedal?
File Type: jpg
Old Oct 20, 2010 | 09:41 PM
jeff spahn's Avatar
jeff spahn
I'll hazard a guess and say it won't let the car start unless the clutch is pushed in. All of my manual cars had a micro switch that did this.
Old Oct 20, 2010 | 10:09 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Kills the cruise control.
No five-speed 928 has any starting safety devices.
Old Oct 21, 2010 | 04:27 AM
tailpipe's Avatar
tailpipe
harbour frieght has these little switches not exactly the same but same function about 5 bucks
Old Oct 21, 2010 | 07:08 AM
sendarius's Avatar
sendarius
Wally, does it KILL the cruise control, or SUSPEND it.
My 944 has a similar switch that works to suspend throttle control while you change gears. Cruise automatically re-engages when the clutch is fully up again.
It can be *fun* when you go clutch in and coast to a corner while you leisurely change down - full throttle when you go clutch out in a lower gear. Wheeee!!
Old Oct 21, 2010 | 07:43 AM
jon928se's Avatar
jon928se
Suspends it momentarily.
IIRC with the vacuum controlled cruise it releases the vacuum.
Old Oct 21, 2010 | 08:37 AM
Herman K's Avatar
Herman K
Default You da..man
Your such an awesome source of information about these cars.
Can you confirm the location on the wiring diagram as - sheet 10 - D84/85
Thanks Wally Best to you
Old Oct 21, 2010 | 08:59 AM
WallyP's Avatar
WallyP
Herman, Thanks.
No, the clutch switch is shown in A90.
"Kills" was the wrong term - as Steve and Jon pointed out. I should have added "temporarily" , or otherwise have made it clear that it just prevents engine over-speed while you have the clutch pedal depressed.
Old Oct 21, 2010 | 09:50 AM
jeff spahn's Avatar
jeff spahn
No starter lockout? Wow, so you can crank the car in gear and move it. Crazy.
Old Oct 21, 2010 | 11:47 AM
Herman K's Avatar
Herman K
Default And if you do...
The garage door will be toast..she moves!
That's why I had to ask the question.
I just installed one of Porken's clutch pedal travel limiter stops and observed the switch and thought it was meant to prevent the car from starting while in gear.
Thanks to all who have replied.
Happy motoring
