pod switch and CE panel spade connector part numbers?
I found a wire between the fog lamp pod switch and the CE panel multiwire connector that was scorched all the way across. As suggested, someone probably pulled the switch without disconnecting battery ground. It looks like it carries 12 V between the pod switch and the fog lamp relay. The circuit still works, but I would like to replace the wire. I do need a proper female spade connector at the pod switch end, and (probably) the same at the multiwire connector at the lower CE panel edge. Anyone carry the connectors, or know a source?
