I really need some help please? Crank poisition sensor removal
#46
Excellent! The dent must have been caused be a previous clutch removal/replacement? The workshop manual has a specific comment to mind the sensor during the procedure.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#48
#51
Strangely enough not long after I bought the car it went back under warranty as it became difficult to select the gears. Although the cltuch had been replaced in fairly recent times the spigot bearing (if that's the right name?) that supports the input shaft, which had apparently doesn't come with a new clutch, had collapsed and they had to remove the clutch to replace it. Perhaps this is when the damage occured and it's been slowly deteriorating since then. I don't know where else the damage would have come from. I don't know enough about these cars yet to know if this would have contributed to it's demise or not?
