Tail lights filling with water?
My tail lights have been filing with water and blowing bulbs so I decided to investigate. The housing above the stoplight section of the bulb was cracked from who knows how much cumulative heat over the years. I filled in the cracks with silicone caulk. There is a vent hole in the lens so I left that open to let condensation out.
If you are getting water in your tail lights, check above the stop lamp. I bet it is cracked.
I'd also drill some drain holes in the bumper, under the lights so the water drains out of there too.
Chronic Tool Dropper
+1 on the drain holes in the bumper shell cavities. And put some thin weatherstrip around the lamp housing where it fits into the body. Keeps a lot of water out of there to begin with.
