928 Forum 1978-1995
Sponsored by: 928 Specialists
High beam and indicator light question
Old Sep 20, 2010 | 06:48 AM
tilac999's Avatar
tilac999
Default High beam and indicator light question
Hi, I'm a new owner and just had my car inspected. One of my high beams was out so I replaced the bulb, H4 and still no joy. Also my high beam indicator is not functional and I was wondering if the two are related or is it just a dead indicator bulb? Not looking forward to removing the pod....
Everything else works perfectly and the car has cleaned up nicely since I went to the Sharkfest in Boston last weekend.
Brad
Old Sep 20, 2010 | 07:26 AM
ammonman's Avatar
ammonman
For the no high beam condition, check that the high beam fuse for that light is good then check the wiring harness inside the fender for breaks. On my S4 there are separate fuses for low and high beam for each side (a total of four fuses). The action of the headlights going up and down often pinches the harness between the headlight mechanism and the body and causes a break in the wiring. To check the harness, remove the wheel and then remove the fender liner followed by the access panel (s).
Hope this helps.
Mike
Old Sep 20, 2010 | 09:40 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
does the Hi beam indicator light come on when you pull back the turn signal switch with the lights in the up and on position???
It could be a burned out bulb in the pod.
Do the wire harness inspection as Mike suggested the wires break where they are clamped with the metal tab just under the headlight pivot.
If you can add a bit of wire to loop then reclamp it a simple tug on the harness should be enough then test the lights up and down to check your work
Old Sep 20, 2010 | 06:10 PM
tilac999's Avatar
tilac999
Thanks much for the helpful info. I'll check the fuse(s) and harness next. Most likely the high beam indicator bulb is blown, won't come on when lights up and on and I pull back on the switch. Cheers.
Old Sep 21, 2010 | 07:27 PM
tilac999's Avatar
tilac999
Just goes to show what a newbie I am. I had no idea each beam and each light had its own fuse. Replacing the bad fuse got my left highbeam working again AND the indicator light as well. Love it.
Now my dash pod lights are acting up but I think it's the rheostat.
Thanks guys.
Old Sep 21, 2010 | 07:46 PM
ammonman's Avatar
ammonman
I would still carefully inspect the wiring for the light with the blown fuse for bare spots. Fuses blow for a reason. Glad you've had success so far.
Mike
