ABS Black Rubber Plugs
How do these plugs come apart. There is 3 of them on pass. side fender well. I need to know the secret please. Could not find any info on search.
Thomas
Thomas
The ones I am talking about on 1988 are inside fender well and they are used to clamp the harness in place. I have the big white one off but the little black ones don't have any clips. They look like they come apart but won't. Sorry I did not post the year in original. Still learning.
I've been sitting here hoping someone would post a picture, I had no idea what the OP was talking about. Thanks.
And yes, those are part of the harness, and just pull out.
Yes that is one. I thought they come apart also to make a quick change if needed. Aren't they a plug also. Thank you for finding the pidture also.
Archive Gatekeeper
They're not a connector, just a collar and a sleeve for routing the wheel sensor harness.
For posterity, here's the left rear ABS and brake pad warning sensors disconnected from the barrel connector. 'Scuse the dirt.
Thomas
