S4 Side Marker
Almost Deleted
I recently noticed that I had an intermittent side marker warning light. I finally had a chance to go through the normal troubleshooting process this afternoon [despite the humidity in DFW]. I ended up cleaning all the grounds, checking all the normal plugs... blah blah blah... well, ended up pulling the light housing apart and this is what I found. I'm pretty sure this is the culprit.
GOO!
GOO!
Almost Deleted
the drain was definitely clogged. rather than mucking with the housing, i just ordered a new [used] one. air on the safe side
Wow..sometimes its a normal failure, not a "First, remove the fuse panel relay B, wiggle twice, then apply test lamp to the 2a fuse, third from the left, and open the doors three times."
