Well, Need some advice on tensioner rebuilding
Captain Obvious
Super User
Super User
Another vote for ProKens tensioner...simple design, sealed. Once you make the first investment the only thing that needs replacing in the future is the Audi tensioner ( $60 ? I think or there abouts ) and the pulley which needs to be replaced even if you rebuild the old tensioner. No rubber boots to fit, clamps, washers to clean and sort, and no adding oil...EVER!
Thanks for the tips and links guys. Thanks for the porkensioner tip. I am kind of leaning towards doing a complete front end refresh. Need to think it through some more.
Dwayne's page is amazing. Looks like you can do it on a rainy Sunday afternoon with one hand turning the wrench en the other holding a cold beer. Of course that's with an unrealistically clean engine, all tools at hand (even the odd ones) and no bolts breaking.
Internet engineers, you can't take them anywhere......
What did 928 owners do before the addition of the TB warning light? I guess thats a reason to avoid ownership of those models...... I think not.
I'm fine running the sealed Audi system...change on time...In my mind when you hold both in you hands...the Audi tensioner has less to go wrong.
I've got 4 stock ones and a spare rebuild kit.
Pretty simple and inexpensive refurb.
Dwayne's pictures really are helpful if its the first time you've done a rebuild.
Kind of a non-issue to me once you know its maintained.
Am watching for changes in tracking on all of them and lights too on the later cars.
Theres one here with the audi-based system, too.
Captain Obvious
Super User
Super User
Nahhhh... try first had experience.
I had a couple of early 90's Mitsubishi 2.0L's that have the same tensioner design and at first glance they are very close to the Audi units (even made comments regarding this when Ken was first developing the kit). The Mitsubishi tensioners were well known for loosing pressure and getting the belt so loose that it would jump. Even the ones that were operating as designed, had major issues when the factory turbochanrged engines received heavy modifications. The two engines I had and worked on kept loosing the pressure and I resorted to manually over ride it and make it into a static tensioner system. My neighbour loost several valves on 3 seperate occasions to this on his modified Talon TSI. This was over 6 years ago but since the Audi pensioner works on the same principle, re instating the factory belt warning light wouldn't be a bad idea.
That's comparing apples to oranges. I trust the system Ken has developed and tested. They have been on countless cars for a few years now with no issues reported.
Everyone has varying opinions on everything about these cars, and I respect yours. The stock tensioner is a time tested design, but there is a better system available now, IMO.
It would be nice to have the warning light integrated into the PKsn'r for added engine safety and peace of mind though.
Has anyone had a PKtensioner failure? I think they've been on the street since 2008. (not counting Audi's...) The way the pulley flops around on the tensioner, it doesn't seem like it would take much to put a sensor that would ground if the pulley moved too far. Maybe that will be on the new and improved model when we all replace them in a couple years.
Has anyone had a PKtensioner failure? I think they've been on the street since 2008. (not counting Audi's...) The way the pulley flops around on the tensioner, it doesn't seem like it would take much to put a sensor that would ground if the pulley moved too far. Maybe that will be on the new and improved model when we all replace them in a couple years. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Anyone track cars out there usng the PKtensioner? I do some lapping from time to time and would be interested in switching to this product if it has a good 'track' record, pardon the pun.
