928 Forum 1978-1995
Sponsored by: 928 Specialists
Kickdown relay testing
Old Sep 9, 2010 | 12:02 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Default Kickdown relay testing
I have removed my kickdown relay so I can check to make sure it is working properly. The part number is 928.618.109.01 and it has a little wiring diagram on it.
The power flows though 30 - 87a, normally closed and the relay opens with a signal from the LH. On the diagram, terminals 31b, 15 and 31 all connect to the electromagnet that activates the relay. Terminal 31 connects to 30 with a diode, which tells me that this feeds the electromagnet on the relay 12v when the kickdown switch on the pedal is pushed down. Would that make terminals 15 and 31b ground terminals that get grounded by the LH to complete the circuit?
File Type: jpg
Old Sep 9, 2010 | 01:46 PM
John Speake's Avatar
John Speake
31b receives 12v square wave rpm signals from the LH, so to test you will need to feed an rpm signal in.
The contacts are fed igntion switched 12v via the kick dowon switch and when the relay solenoid is energised these volts are fed via 87 to the kick down solenoid on the auto 'box.
The relay coil is energised by a combination of the rpm circuit above, plus igntion switched 12v on 15 and the permanenty ground on 31 on the other end of the coil.
Old Sep 9, 2010 | 02:32 PM
Cosmo Kramer
OK I see now I wasn't looking at it right. 31 connects to 87A with the diode so it must ground through the kickdown solenoid. I wish there was a way to bench test this solenoid so I could know if it was working properly. If the magnet doesn't open the relay contacts it could be what is causing my issue with hitting the limiter on the 2-3 shift. If I lift on the gas pedal just a little bit slightly just before redline it will shift because I am releasing the kickdown switch.
Old Sep 9, 2010 | 02:52 PM
John Speake
I've never bench tested a kick down relay. I just found this explaination opf the relay operation on Theo's site..... from Wally Plumley
The only function of the kickdown relay is to ensure that the transmission shifts instantly and reliably at redline. The relay receives an RPM signal from the ECU at redline. The relay activates, opening the normally-closed contacts. This breaks the signal from the kickdown switch under the throttle pedal, causing the transmission to upshift instantly. As soon as the transmission shifts, the RPM signal disappears, the relay deactivates, the N-C contacts close, and you are back in kickdown mode (eager to downshift, reluctant to upshift).
Wally Plumley
So it appears that if the RPM detect circuit is not working (or rpm signal not appearing at relay) then this could cause the issue you describe.
Old Sep 9, 2010 | 04:11 PM
Cosmo Kramer
Yes that is what I was thinking as well. If the relay is not energizing it is basically the same as having 30 and 87 jumpered. It could just be that I need a higher rev limit with the supercharger (currently at 6500, i have a new LH chip from Ken on the way bumping it to 6700). I would just leave the relay out and shift manually but when I do that my 1-2 shift drops to 4500 rpm.
Wally Plumley
Old Dec 26, 2017 | 05:01 PM
Alan's Avatar
Alan
Electron Wrangler
The diode here is a protection diode. 31 is always ground - in all normal operation the diode is reverse biased (not-conducting). Since the solenoid that is being driven is highly inductive - the diode protects against big negative spikes created from this coil inductance when the relay switch terminals open. Don't try to read any other functional significance into the diode... there isn't any.
The active state of the kick down relay is when it opens the circuit.
Alan.
Old Dec 26, 2017 | 09:48 PM
The Forgotten On's Avatar
The Forgotten On
Holy thread revival Batman!!!
Old Dec 26, 2017 | 11:00 PM
Alan's Avatar
Alan
Electron Wrangler
Well ...This thread got referenced elsewhere today. Whenever I see confusing data back in current use (even if from an ancient source) - I like to clear up the confusion.
Yes quite weird I know..
Alan
7 Porsche Models That Have Aged Like Fine Wine
Old Dec 28, 2017 | 02:15 PM
Bertrand Daoust's Avatar
Bertrand Daoust
Not weird at all!
It's because of your great quality posts with very good advices that we can have better 928s.
Thanks and Happy New Year to you and to all great valuable members here.
Old Jul 26, 2021 | 10:26 PM
545svk's Avatar
545svk
Alan.
I understand this to mean that the relay does not activate the kickdown solenoid, but protects the engine / gearbox by preventing kick downs that will over rev the engine.
If this is correct, does this mean that I should be able to measure a current at the kick down solenoid if I have current at the switch, and the switch is working ( which I have)?
Also, my kick down relay looks very "home made" compared to the images online. Does anyone know anything about these?
Dawid
'87 s4 auto
Old Jul 27, 2021 | 12:33 AM
Alan's Avatar
Alan
Electron Wrangler
It doesn't work the way you think.
The kickdown is enabled by the WOT (kick-down) switch under the pedal driving the kick down solenoid through the normally closed relay - the relay operating (opening) causes the up-shift at the RPM limit by disabling the kickdown solenoid briefly - just as if you took your foot off the throttle (just off WOT) briefly.
Alan
Old Jul 27, 2021 | 05:23 AM
545svk's Avatar
545svk
Alan
Thanks Alan. The switch I mentioned is the WOT under the pedal.
At the moment, I don't think my kickdown works, as I cannot get the double downshift when flooring the pedal at low revs in 4th. I am working my way back from the pedal to check and adjust everything.
What I want to understand is whether, if I engage the WOF switch, should I be able to measure a current at the solenoid?
Old Jul 27, 2021 | 07:57 PM
Alan's Avatar
Alan
Electron Wrangler
Yes you you should be able to measure the solenoid current when operating. Connect wiring for a remote switch to the throttle connection point so you can operate a WOT/Kick-Down switch and monitor the current remotely. This also takes out the uncertainty of whether the pedal is operating the switch... evaluate.
Alan
Old Jul 27, 2021 | 08:52 PM
545svk's Avatar
545svk
Alan
Thanks Alan - tracing these gremlins are frustrating, but rewarding when fixed.
Old May 23, 2023 | 07:14 AM
CliffH's Avatar
CliffH
Still having issues with my 83 not changing up. I think I have the cable now adjusted fairly spot on.
Thinking outside the box, would I get the issue of not changing up unless i slightly back off the gas pedal if either the kick down switch or relay were faulty? 🤔
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
