928 Forum 1978-1995
Sponsored by: 928 Specialists
TB Tension Warning?
Old 09-12-2010, 02:56 PM
  #31
zekgb
zekgb's Avatar
Bingo. Pretty much the same behavior Bill and I saw on my car. Glad you got it solved, that particular warning light sure gets the blood pumping doesn't it?
zekgb is offline
Old 09-13-2010, 11:37 PM
  #32
WICruiser
WICruiser's Avatar
Yea, as many times as I checked the belt tension, every time that light came on my blood pressure would jump. I kept telling myself that it was not really loose, just the warning system, but thinking of the valves and pistons running into each other, and needing to pull the engine to remove the heads would not let my logic prevail.
WICruiser is offline
Quick Reply: TB Tension Warning?
