A/C drain holes?
1 Post
Where in my 82 are the drain holes for the a/c system to drain, I never see water on the floor, and secondly, where are the air intake vents for the interior cabin??
Thanks.... Rick
Thanks.... Rick
The A/C condensate drain is right behind the bellhousing above the torque tube. On most 928's they get clogged up with crap and don't flow properly, which is probably why you are not seeing any on the ground. The fresh air comes in through the recirc box which is directly above the fuse/relay panel.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
