85S Hissing sound or high pitch sound under center intake
I'm visting with the parents this weekend and my dads 85S is making a hissing sound which gets louder as revs go higher under the center intake runner. What would be causing this? The hissing sound doesn't start until the car starts to warm a little than it gets louder as the revs climb. It really sound like he has a supercharger under there! lol I'm pretty sure it isn't the vacum lines as it sounds more mechanical. Only thing I can think of is idle stablizer?
Team Owner
you might try looking under the intake for a loose fitting MAF or a cracked air line, use a piece of hose to zero in on the noise
Any way to shoot a little audio video clip?
There's a big boot in there, the butterfly valve seals, the TPS that has seals on that same shaft, the intake gaskets, some injectors in the vicinity, not much else.
How is it running?
How is it running?
Car runs great only problem is the hissing sound you hear now directly under the center intake tube. Very weird never heard anything like it. Makes the car sound like its boosted. Gets louder as revs climb. I figured it might be a common problem but it doesn't sound like it.
Weird thing is this hissing sound doesn't start until the car warms up. I will check around for him. Thanks for all the suggestions.
Team Owner
I would be very careful about spraying anything flammable around the intake.
One bad ignition wire will have a quick ball of flames showing up under your hood.
What did you find out by using a hose placed near any of the intake parts and listening??
Team Owner
sounds like great idea Mal
