fuel pressure gauge - leaks
Have you tried e-mailing Carl at 928MS? I am sure he will be of some assistance.
I am not familiar with how his connects to the rail, I have the one from 928srus and it just needs to be tightened very snug. Mine wasn't and I was getting a small fuel mist out of the fitting, lucky I didn't have a car-be-cue!
Oh hell, just put some JB Weld on there, I'm sure that is the right thing to do.
There is a long-ish thread on fuel-pressure gauges here:
https://rennlist.com/forums/928-foru...ure-gauge.html
Roger started that thread with the announcement of a kit that used teflon tape for sealing, and which was followed by much discussion. Bottom line was that a lot of folks (me included) were not happy with teflon tape, sealers, etc.
Roger then went back to the drawing board around post #73 and came up with a new design, which seals using a ball-end fitting the same as the factory fuel lines. And Roger added more details in post #81, and a picture in post #86.
We have one of these new designs, it is nicely done and highly recommended.
Oh hell, just put some JB Weld on there, I'm sure that is the right thing to do. Sean
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
You need to install the o-ring in the grooved end of the fitting, where it tightens up to the fuel rail.
My guess is you don't have the o-ring in there.
My guess is everyone with o-ring comments is off base. I did not get the o-ring initially. I did not install anything but called and requested the o-ring. They sent it and I waited. Then I installed with the ring in the proper location and had a leak. Disassembled, cleaned surfaces, reassembled and still leaks. Purchase o-rings of different thicknesses with no improvement. Tried the crush ring with and without o-ring; leak leak leak. Maybe my fuel rail needs resurfacing?
Since I had not received the o-ring initially the conversation with Carl’s folks started early. Their suggestion was considered but not attempted as it would have destroyed the o-ring and involved JB weld. That might be good for to try at some point but not at the first variation.
…Waiting on the corresponding part from Roger. …
So, Carl or one of his people suggested JB weld to fix your problem with a part he supplied? Now that's real customer service! I know where I'll be buying my parts from and it sure as hell won't be from Carl.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
My first fuel guage was procured from Carl. Installed with the o-ring, fitting and guage and worked perfectly with no leaks.
Then Roger came out with his version which was essentially what 928sp used to sell with a smaller guage so that was ordered and installed...............no worries.
Fast fwd to last year when a relative local to me needed a fuel regulator to replace his leaky one I offered my used reg as well as the FG (Carls). Its was intalled on his car with the original o-ring, fitting and guage again with no worries.
Moral of my experience...............they both work just great when fitted as they should.
