928 Forum 1978-1995
Sponsored by: 928 Specialists
What fittings lie under the fuel tank strap?
Old 08-28-2010, 08:54 PM
928mac
928mac's Avatar
My leak is at seal ring #3 and the 1/2 hose is rock hard.
I spent all day looking for some bulk 1/2 hose and the square O-ring to no avail.
What is the difference between the two #4 hoses that are listed above
and
dose anyone stock these parts
Old 08-28-2010, 10:16 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,257 Likes on 1,250 Posts
the 2 #4 hoses are for earlier than 91 cars without the internal fuel pump then with the internal fuel pump the earlier hose has a smaller diameter to fit the filter VS the internal pump outlet has a larger diameter.
If you have a leak at the tank there is a good chance it is not the square shaped O ring but rather the metal collar hes become unseated from when the the part was positioned into the tank when it was made.
it cant hurt to try to replace the o ring however.
Get the correct tank to pump hose, Roger has these parts
Quick Reply: What fittings lie under the fuel tank strap?
