928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel Gauge/Sending Unit Question
Old 08-26-2010, 10:31 AM
blaydrunner
blaydrunner's Avatar
Default Fuel Gauge/Sending Unit Question
Okay,
I have searched the forum for an answer....but I can't seem to find one.
1988 928 S4.
My Fuel Gauge reads full at all times. When I unplug the connection for the Sending Unit should the needle drop to empty? Mine STILL shows full.
Is there a short somewhere? Do I need to pull a fuse to "reset" the gauge?
I have a replacement Sending Unit that I plugged into the connection making sure the float was at the bottom.....STILL shows full.
Any clue?
Old 08-26-2010, 10:48 AM
SQLGuy
SQLGuy's Avatar
Sounds like somthing in the cluster itself is bad... although it could be something along the way.
One check that might be interesting would be to take a multimeter and measure from ground to each of the pins of the sender connection (sender disconnected and igntion on). IIRC, two should be 0V, and the other should be about 5.5V. Let us know what you find on yours.
Old 08-26-2010, 02:11 PM
928mac
928mac's Avatar
read through this thread
http://forums.pelicanparts.com/porsc...ght=Fuel+Gauge
Page 2 go's into how to test your gauge with a Ohm meter and so forth
Old 08-26-2010, 02:30 PM
blaydrunner
Thanks!
Old 08-26-2010, 03:24 PM
JoeTaylor
JoeTaylor's Avatar
I have an '88 S4 and I just replaced the sender unit in the tank. It wasnt reading correctly. New sender part cost $130 online (did some shopping around) and took all of 15 minutes to swap out. Easy job.
Joe
Old 08-26-2010, 07:09 PM
jpitman2
jpitman2's Avatar
Stuck float ? Shorted wire in the sensor unit? See snakeskin's pages for details of internals of the sensor. BTDT myself.
jp 83 Euro S AT 52k.
Old 08-26-2010, 08:23 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,281 Likes on 1,265 Posts
when you reinstall the sender to the tank soak the securing nut in very hot water for 5 mins then install it.
Old 08-29-2010, 02:01 PM
blaydrunner
Joe
When you unplugged the old sender....does your needle drop to zero? I'm trying to see if I have a short. I have a replacement sender to swap...but it might be a wiring issue.
I'll get a volt meter and see what I come up with.
Old 08-29-2010, 04:59 PM
JoeTaylor
JoeTaylor's Avatar
Hi blaydrunner,
I would be careful about messing around with the sender with the power on in the car.
My understanding is the fuel sender is a variable resistor, IE the resistance changes as the float goes up and down a thin wire.
I never tested the sender by disconnecting it, using an ohm meter, etc., as it did read, but would read incorrectly after the tank went below a 1/4 full.
I didnt want to "fiddle around" trying to clean the sender's fine wire, just bought the replacement and everything has worked fine since I installed it.
VTY,
Joe
Quick Reply: Fuel Gauge/Sending Unit Question
