A/C not cooling well? Evaporator cleaning.
#48
Gary Knox did add a filter to his HVAC system. It was a cut down house air filter with a coat hanger wire frame. He even sent me one, but unfortunatly I've never installed it and now it's packed in the dozens of boxes in preperation of my move. Maybe Gary will chime in on this one. IIRC it fit into the opening just aft of the rubber boot.
#50
Thanks Herman.
After driving a bit this evening, I can tell you there is a huge difference in A/C temp.
#51
Is it worth pulling the vent out of the center console, and using compressed air to blow through the evaporator from inside the car? (turned down a bit, to 50psi so it doesn't break fins maybe?)
#52
After I had most of it cleaned off, I tried it again with no luck. I fully expected a billowing cloud of dust to hit the wife, and it didn't happen.
#54
One screw inside the blower, pull the boot back and use an 8mm with a flex head. They are small screws. 2nd one is located outside the blower towards the fender. Use a flash light to see it and get aligned. 3rd one is inside the passenger compartment. Also a 8mm. Long bolt. If you have an air bag car, you need to remove the glove box to access it.
Then once those are free, you can move the blower around so you can get to the evaporator.
Hope that helps.
Hope that helps.
#56
Herman,
Your evaporator looks pretty clean!
Here's a few pics I took when changing the filter. To be honest w you, I did this right after I bought the car so I did NOT check the evaporator coils when I pulled the filter. I'm guessing that it had never been changed when I got the car 2 1/2 years ago.
Friggin PO's!!
Friggin PO's!!
#58
Wow that is nasty!
Would it be assumed that an A/C that blows cold doesn't have build up?
#59
Supercharged
No... I would not assume that. It may be that it's not as bad as the example Sean posted. I'm actually quite eager to see what mine looks like. Even though it still blows cold, my guess is that it's nasty nasty nasty.
