928 Forum 1978-1995
Sponsored by: 928 Specialists
It better be what it seems to be (O2 sensor) - UPDATE: Nope, the LH is bad.
Old 09-01-2010 | 10:01 PM
  #31
PorKen's Avatar
PorKen
Inventor
Originally Posted by Bill Ball
I did a timing belt job as it was due. Things looked fine except for worn cam gears, but I replaced most everything, as you should. When I took the old gears off, I marked their position. When I installed the new gears in the same position, they proved to be about 8 degrees advanced according to the PorKen tool! Whoa! They had been more or less centered on the adjustment slot before removal. I adjusted and triple checked them with the PorKen tool, which led them to be almost to one side of the slot, something I hadn't seen before.
A cam gear tooth is 7.5°; there is a ±1 tooth range in the slots.
Sounds like the belt is off a tooth? You have to really try to get both sides off, though. (Speaking from experience.)
Old 09-01-2010 | 10:29 PM
  #32
SeanR's Avatar
SeanR
Just as a data point on to add to this in case others are looking. I thought that was my issue for bad mileage, rough idle, **** poor acceleration was the MAF.
Pulled my coils and found them to be badly corroded internally, you can't see it unless you yank them and look, replaced them and the car runs like a dream. Granted, I did replace the MAF, the plug wires, plugs, temp II previously.
Old 09-01-2010 | 10:50 PM
  #33
Landseer's Avatar
Landseer
Sean, do you mean in the front cup that recieves the coil wire?
Or some further disassembly of the coil?
Quick Reply: It better be what it seems to be (O2 sensor) - UPDATE: Nope, the LH is bad.
