Rear Sway Bar Bushing sets
I've got a DR sway bar and am looking for the parts so I can install it. Got the bar from Sterling, who got it from Jim, who got it from Chuck, who got it from someone else. I helped Brad install his DR (complete) on his '81 and if I remember correctly, it had a different mounting bracket. (might be wrong)
I don't particularly want to source the parts myself. Can anyone give me their opinion of Carls set up http://www.928motorsports.com/parts/swaybarbushings.php for the rear. Are they compatible with the DR sway bar? Do the stops come with Carls kit? I know I can get the bushings about anywhere, and Roger has some in stock, but am needing the stopper/clamp/thingys.
Sean, As you know I also have the 928 Specialists front and rear sway bars. The original specs that Dave published says the rear bar used the factory stock bushings and brackets, so I think you only need the clamp on stops. Perhaps Dave Roberts can provide those.
Sean,
DR's rear bar uses the stock bushings/mounts. Using a stiffer bushing like Carl's may not be a bad idea, but you arent "missing" anything from your bar, as the instructions said to use the stock ones. Here is a link to the install instructions:
https://www.928gt.com/rearswaybarinstall.htm
Hope that helps,
Hans
Hope that helps,
Hans
Copper Anti-Seize works great for greasing the bushings!
Webster and Blandis had me do this on the front bushings almost 2 years ago and I haven't had 1 squeak!!
Sean, do you just want my front and rear Louie drop links?? You can have the Webster front bar with it when the time comes. I just got my DR front and rear bars yesterday.
