Devek Big Brakes
Devek big brakes were 993TT or GTS fronts and 993TT rears. The rears were machined to let them fit the 928 mounting points. So the pads are GTS or 993TT fronts and 993TT rear pads.
Wayne, some of the Devek kits used theS-4 size caliper also, so you may want to check to see which pad will fit, or get both sizes and return the one you don't need..
