L-Jet FP relay pin out?
84 L-Jet
Can anyone tell be where these pins connect my diagram is not readable?
30 Power on constant
87 Ground
31 ?
15?
31b?
I assume that an LH uses the crank sensor for safety to shut off the Fuel Pump in case of a crash. The L-Jet seems to be doing the same thing but not sure what pin 15 and 31B goes to.
87 Ground
31 ?
15?
31b?
Megs Squirt conversion:
87 Power feed to fuel pump
31 Ground
15 Ing 12v switched position 2 and 3
31b To pin 16 of Amp and pin 1 of LH
I believe the Lh is providing ground to the relay when motor is cranked and key is in run position, this provides a safety to turn off FP when motor is stopped.
This is for a Mega Squirt conversion I believe we can hook pin 31b to pin number 37 to provide the ground and still use the factory relay.
Tell me if I am wrong!!
31 Ground
