Quick question for the Gurus!
Team Owner
the radiator will fit , BUT the fan shroud will be missing the center attach points that are part of the older style radiator, also the fan switch on the front of the radiator will not match up unless you swap it out ,
the later cars have a fuel injector type connector.
the early cars have 2 male pins sticking out and female connectors slide on separately
