looking for a good used transmission for a 84
does anyone have any idea where I could pick up a good used auto transmission for a 1984s ??? I have found them at a couple of on-line sites (german auto dismatlers) but they are asking $1500+ for transmission, I could have my current tranny rebuilt for that price. One would think a used transmission would be somewhat cheaper than that ?? thanks everyone, my car has been sitting for about two months and I am going crazy !!!
If you are replacing the transmission with a used one, before installing it I would suggest;
Replace the torque converter bearings.
Replace the front pump seals.
Replace the the filter and pan gasket.
Replace the rear flexplate rivets with bolts.
Check the kickdown solenoid functionality.
When I replaced my transmission (84S), these items were recommended to me by several people (including transmission experts).
It will cost more; however, it will make your used transmission experience much more enjoyable
From what transmission guys have said, over time the rear flexplate rivets loosen and cause play.
This is corrected by replacing the rivets with bolts.
I am not sure if there is a technical bulletin on this or not.
Cheers,
Cheers,
