difference s4 vs gt
Inventor
Here's a few things that are different with the 89 S4 comparing the 88/87 S4 model.
Credit- David Roberts.
>> Here are the differences/upgrades between an 88S4 and 89S4 928
**>> 89 has the lower Euro gearing , 2.64 (89GT is 2.72) vs 88s 2.20 (auto
2.54 vs 88s 2.20)
>> 89 has improved cylinder heads for better breathing
>> 89 has more advanced computer engine management system.
>> 89 has additional timing belt idler/stabilizer
>> 89 has Updated Back-Lit Instrument Cluster with 21-function Computer
>> Electronic Information and Diagnostic Display System
>> 89 has Standard 10-speaker Stereo system with 6-channel amp
>> 89 has Anti-Theft System as standard equipment.
>> 89 has "cute" little flashing Alarm LEDs in the door lock posts to warn
off intruders
**>> 89 has capability of locking doors from hatch lock (some late 88s have
this feature also)
>> 89 has Roof Mounted antenna (fin)
>> 89 has Standard Rear A/C system
'89 S4 GP White/Black
'76 912e Silver/Black
2.54 vs 88s 2.20)
off intruders
this feature also)
Just got the new PCA Panorama last night. Did anyone see the listing for a 1990 928 GT for $11,500 under 100K miles for sale in the classifieds I think it was in New Jersey. I thought that my be worth checking out........I'm not at home,otherwise I would have listed it's details.....
I'll gladly take a look for someone if it's still available.
According to my 928 brochure, main differences with GT are:
Manual
Sports seats
Sports suspension
20kg lighter
'Sportier' torque curve and gearing
10 bhp more
And I believe it was about £15000 more expensive!
Manual
Sports seats
Sports suspension
20kg lighter
10 bhp more
There are differences between countries in the differences between model years.
US GT's did not get sport seats. Here's the whole listing from 928 registry:
1989 928 S4/GT VIN Range - WP0JB092_KS860001 - 1250
* 1989 928 GT base MSRP to: $74,545 + $1,300 gas guzzler tax
* 928 S4 automatic gets revised shift program (holds a gear longer when accelerator pedal is to the floor)
* Break pad wear indicators
* Radio antenna moved to roof
* Computerized dash read out reports miles, outside air temp, gas mileage, trip odo, miles to empty......
* 928 GT introduced as a late model year addition (It appears that the 928 S4 5M was still built during 89 GT production. It is critical that claims of a 1989 928 GT be verified both visually and with option codes)
* 1989 928 GT production begins in March 1989 and ends in June 1989
* The earliest 1989 928 GT currently recorded has a VIN of 1107
* 1989 928 GT power increased to 326 bhp & 317 ft/lbs
1989 928 GT is differentiated from the 928 S4 in the following ways:
* Rolled fender lips front and rear
* Lightened twin outlet exhaust
* Shorter shift lever
* Different intake (same as GTS)
* GT camshafts
* 17 mm Rear wheel spacers
* Short ratio manual transmission
* Wheels were 8x16(front) and 9x16(rear) "club sport" with an offset of 60mm with 225/50 16(front) and 245/45 16(rear) tires
1989 928 GT is further differentiated from the S4 by the following options (option codes are located on the inside cover of and original owners manual or on a white sticker located in the rear hatch area opposite the spare tire and above the gas tank):
* 220 - 40% Limited Slip
* 393 - Forged Alloy Wheels
* 474 - Sport Suspension
* 481 - 5-speed transmission
* 639 - 1989 928 GT
1990 928 S4/GT VIN Range - WP0JB092_LS860001 - 0581
* Base MSRP up to: $74,545 + $1,300 gas guzzler tax
* 928 GT(5-speed) power remains at 326 bhp & 317 ft/lbs while 928 S4(automatic) stays at 316 bhp & 317 ft/lbs
* Dual airbags appear in the 928 for the first time
* Tire pressure monitoring system (RDK)
* 928s with 5-speed are now GTs
* Design 90 style wheel introduced on the 928 (flat disk style wheels still available)
* Electronically controlled limited-slip differential (PSD) on all models
* Twin outlet muffler on both S4 and GT
* Wheels were 7x16 front and 8x16 rear flat disc with an offset of 65mm(front) and 52.3mm(rear) with 225/50 16(front) and 245/45 16(rear) tires
* Standard on 1990 and 1991 928 GTs and optional on S4s were 7x16(front) and 8x16(rear) "Design 90" style wheels with an offset of 65mm(front) and 52.3mm(rear) with 225/50 16(front) and 245/45 16(rear) tires
* VIN tags on all body panels eliminated
1991 928 S4/GT VIN Range - WP0AA292_MS810001 - 0448
* Shorter more ergonomic shift lever in the 91 928 GT
* Cooling flaps in front of radiator eliminated
* Improved door seals to reduce water dripping on occupants during rainy weather
* GT camshafts
* 639 - 1989 928 GT
S4 430Nm@3000rpm
![](http://members.rennlist.com/vilhuer/1987-11.jpg)
GT 430Nm@4100rpm
![](http://members.rennlist.org/vilhuer/1989-2.jpg)
GT production split between markets.
Code:
1989 C00 Germany LHD WP0ZZZ92ZKS841332 - 842477 198 C02 USA LHD WP0JB292_KS861096 - 861240 71 C03 California LHD WP0JB292_KS861110 - 861244 29 C05 France LHD WP0ZZZ92ZKS841682 - 842273 40 C07 Italy LHD WP0ZZZ92ZKS841990 - 842355 9 C08 Japan LHD WP0ZZZ92ZKS841739 - 842284 7 C09 Sweden LHD WP0ZZZ92ZKS841634 - 842483 11 C11 Austria LHD WP0ZZZ92ZKS841626 - 842187 6 C16 UK RHD WP0ZZZ92ZKS841637 - 842484 60 C20 Holland LHD WP0ZZZ92ZKS842392 1 C22 Belgium LHD WP0ZZZ92ZKS841856 - 842274 13 C23 Australia RHD WP0ZZZ92ZKS841873 - 842384 3 C26 South Africa RHD WP0ZZZ92ZKS841702 - 842408 5 C27 Spain LHD WP0ZZZ92ZKS841494 - 841696 2 C36 Canada LHD WP0JB292_KS861089 - 861191 15 C80 ? LHD WP0ZZZ92ZKS841867 1 C99 Special LHD WP0ZZZ92ZKS841741 1 472 1990 C00 Germany LHD WP0ZZZ92ZLS840062 - 842651 356 C02 USA LHD WP0JB292_LS860074 - 860517 92 C03 California LHD WP0JB292_LS860068 - 860503 37 C05 France LHD WP0ZZZ92ZLS840125 - 842554 117 C07 Italy LHD WP0ZZZ92ZLS840169 - 842394 42 C08 Japan LHD WP0ZZZ92ZLS840122 - 842307 23 C09 Sweden LHD WP0ZZZ92ZLS840497 - 840891 2 C10 Switzerland LHD WP0ZZZ92ZLS841352 - 842579 19 C11 Austria LHD WP0ZZZ92ZLS840151 - 842423 7 C12 Denmark LHD WP0ZZZ92ZLS840946 1 C13 Finland LHD WP0ZZZ92ZLS840106 1 C15 Hong Kong RHD WP0ZZZ92ZLS840557 1 C16 UK RHD WP0ZZZ92ZLS840178 - 842631 125 C18 Japan RHD WP0ZZZ92ZLS840074 1 C20 Holland LHD WP0ZZZ92ZLS840235 - 842366 8 C22 Belgium LHD WP0ZZZ92ZLS840242 - 842442 31 C23 Australia RHD WP0ZZZ92ZLS840258 - 841975 18 C26 South Africa RHD WP0ZZZ92ZLS840483 - 842006 10 C27 Spain LHD WP0ZZZ92ZLS840101 - 842530 30 C31 Saudi Arabia LHD WP0ZZZ92ZLS841003 - 841271 3 C32 Arab Gulf States LHD WP0ZZZ92ZLS840957 - 842404 5 C36 Canada (no bags) LHD WP0JB292_LS869061 1 C36 Canada LHD WP0JB292_LS860193 - 860493 15 C80 ? LHD WP0ZZZ92ZLS840380 1 C99 Special LHD WP0ZZZ92ZLS840224 - 842264 7 953 1991 C00 Germany LHD WP0ZZZ92ZMS800065 - 801710 263 C02 USA LHD WP0AA292_MS810062 - 810447 139 C05 France LHD WP0ZZZ92ZMS800082 - 801666 72 C07 Italy LHD WP0ZZZ92ZMS800132 - 801647 32 C08 Japan LHD WP0ZZZ92ZMS800108 - 801370 38 C10 Switzerland LHD WP0ZZZ92ZMS800148 - 801261 21 C11 Austria LHD WP0ZZZ92ZMS800144 - 801643 2 C12 Denmark LHD WP0ZZZ92ZMS800135 - 801318 2 C15 Hong Kong RHD WP0ZZZ92ZMS800816 1 C16 UK RHD WP0ZZZ92ZMS800117 - 801508 42 C19 Luxemburg LHD WP0ZZZ92ZMS801219 - 801255 2 C20 Holland LHD WP0ZZZ92ZMS800085 - 801444 5 C22 Belgium LHD WP0ZZZ92ZMS800112 - 801665 13 C23 Australia RHD WP0ZZZ92ZMS800097 - 800246 2 C26 South Africa RHD WP0ZZZ92ZMS800139 1 C27 Spain LHD WP0ZZZ92ZMS800217 - 801524 17 C36 Canada LHD WP0AA292_MS810093 - 810288 6 C99 Special LHD WP0ZZZ92ZMS800525 - 801513 3 661 2086
GT: revs at 3200 rpm at 80 mph due to 2.73 rear end
S4: revs at 2400rpm at 80 mph due to 2.20 rear end.
That's the biggest difference you would notice from the driver's seat. If you cruise at 85 mph the GT will feel like you need another gear and the S4 won't.
But you're right Ryan - why we are tripping over ourselves doing smyth's research for him is a mystery.
I don't post about wheels. I just don't care, really. They could look like this, they could look like that, but they are all shiny. Big whoop.
