Information stalk repair help needed!
My information/control stalk for the computer control can 'scroll' up and down plus push forwards but does nothing when I pull back.
I've telerated it so far (can't reset Average MPG, change miles/kms etc) but now that I get the brake pads sensor alert I can't reset it so time to fix stalk (and sort brake pads of course).
Is it easy to repair, assuming it the switch contact?
Dan
1990 928GT UK.
Dan
1990 928GT UK.
I thought my stock was broken , turned out to be the mounting screws were loose . so I have a new unit sitting in a box . Try seeing if the unit is loose on its mounts . Terry
So I've taken steering wheel off, removed the information stalk and then disconnected it. I got some wire to bridge connections so that pulling on stalk operated another action and proved that (annoyingly) the switch is working perfectly.
I then had the wire going from the brown live in pin 1 and tested the dash computer inputs by touching each pin (with the engine running) and the pullback pin 5 did nowt. I made sure that I was in the 'change centre display' mode (push forward) as otherwise pull back may not result in an action.
By the way:
pin 1 live/input (not sure what to call it)
pin 2 and 3 are up and down
pin 4 is the push forward
pin 5 is the pull back
pin 6 empty
So perhaps the pin 5 lead is not attatched properly to the onboard computer. Not what I want to fiddle with it but will hunt for a way to access it to test.
Worried I might damage onboard computer (£££/$$$
) to fix a problem that is handy but not nessesary (can't cancel alerts/reset average mph n' mpg).
Arg!
By the way:
pin 6 empty
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Arg!
