928 Forum 1978-1995
Sponsored by: 928 Specialists
Flatbed Towing Only?
Old Jul 10, 2010 | 01:37 PM
PatrickP's Avatar
PatrickP
Default Flatbed Towing Only?
I have only had my '85 auto towed a couple of times and that has always been on a flatbed. Is this the rule of thumb or is it permissable for it to be lifted from the rear and towed? Thanks.
Old Jul 10, 2010 | 02:05 PM
James Bailey's Avatar
James Bailey
Odds are they will lift it up and then the front spoiler will drag even the flatbed guys have trouble loading and strapping down a 928...they OFTEN put hooks on the rear spring plates and BEND them !
Old Jul 10, 2010 | 02:20 PM
Franks928s's Avatar
Franks928s
SO true! sometimes they will often lay out a couple of t2x4's to gain more clearance when pulling it on to the bed but I had an experience with one where they bent my front spoiler almost in half. Sometimes getting it back off the truck is of equal challenge. I suggest you take pics of your front end/spoiler (including both side pics of where it wraps to the fender) before loaded and once loaded. It served my purpose of the tower paying for the replacement of a new spoiler on one occaision when I was not at the drop-off point to watch the unload..
Lastly - to Jim's point, where they hook-up to can also be a challenge. I've insisted they use the front screw-in tow ring when I've had this need.
Frank
Old Jul 11, 2010 | 02:58 PM
VehiGAZ's Avatar
VehiGAZ
My last tow (always on a flat-bed when Hagerty's is paying) was done very professionally. The driver insisted on using the rear tow hook, and he kept wiggling the bed back-and-forth to get a good angle on it so that NOTHING scraped. If a guy wants to rush it and not do it properly, tell him to stop immediately and get his supervisor to send someone else - he'll take his time after that.
