!979 rear brake filler plates missing
So I pulled off the rear wheels this weekend to start the brake caliper rebuild, flex hose replacement and do the fuel line replacement and discovered that the filler/protective/dust plate (sheet metal dust shield) is not installed on either side.
How urgent a condition is this? can I live with them not installed while I source a new set?
They probably got pulled off after they got torn up or maybe because the PO thought the brakes would cool better without them. Blackshark will have some for you. PM him.
