high pitch squeeling at idle
I recently noticed a high pitch squeeling niose at idle at my '82 euro.
Thetiming belt was recently changed by a reputable shop and nothing else has really changed.
I disconnected all three belts up front one by one and no change, so it is not an issue with belts or alternator, air pump, power steering...
I placed a hose on top of the timing belt cover vent hole and don't hear it from there. Timing belt looks centered and does not seem to rub anywhere.
I can't really tell where it comes from, but seems at the front, but rear not out of the question.
Have a pretty bad oil leak at the rear of the engine, which is not pinpointed yet either.
The noise is only audible at idle, car runs strong and makes no noises under power.
What to do? Ignore it, take it to the track and drive it like i stole it, or reasearch further?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Any suggestions are greatly appreciated.
cheers,
cheers,
sounds like it might be the water pump. Was that changed with the tb?
Team Owner
was the oil pump o rings changed?? if so they may have not put the pump back together and it can seize in the block the outer ring gear has a dot stamped into it this dot should match with the drive gear and they both face towards the engine .
The water pump may also be suspect i would not run the engine any longer than to diagnose this noise as you could be causing catastrophic damage to the engine
Team Owner
without major disassembly you could rain the radiator at the lower plug then pour some of the coolant into a white bucket and see if can spot any mettallic particles they will be easy to spot do this inspection in the sun same goes for the oil get a piece of lamp coord put it into the dipstick tube
( the reason for the lamp cord is so you dont make more metal and get a false reading every time you pull out the dipstick it will grind on the tube and metal shards will come off).
and drip the oil onto a black piece of cardboard look at the oil in the sun if you see lots of metallic particles then you may have an oil pump getting ready to seize.
If both of these test are negative for metal then its quite possible one of the idler bearings may be rubbing on the waterpump securing bolts
thanks for all the suggestions.
One more detail. It does not squeel at all when cold, just after about 5 minutes when engine is warmed up...
Any chance the noise is coming from one of the other systems in the front ?
Before going in, I would remove all the belts in the front of the eng, Pwr Steering, Alt, AC Comp, Air Pump (if still installed). You could also do them one at, start w/ the outer most and work your way in.
Start eng and listen
the problem I am facing is that the squeel will only start when the engine is hot. So I am worried that if I take the car apart to look at the T-belt, it may not be apparent what makes the noise...
Is there a way to get a a listen to the water pump and oil pump while the car is running?
This is very frustrating, as I have a free open track day tomorrow and all is ready to go to run the car (besides the noise...).
Sorry I scanned and did not Read this: "I disconnected all three belts up front one by one and no change, so it is not an issue with belts or alternator, air pump, power steering...".
Sab can you get a complete listing of the "new" parts that were changed w/ the "T" Belt service ?
But I would not drive it until you find out the source of the noise, if the belt breaks your looking at big bucks to repair the valves/heads.
