928 Forum 1978-1995
Sponsored by: 928 Specialists
Stud Kit
Old Jul 5, 2010 | 07:52 PM
aaddpp's Avatar
aaddpp
Default Stud Kit
In the process of installing my oil pan stud kit, but have no instructions. Do you lock-tite the studs in place? What are the lengths you should make the studs?
Dave
Old Jul 5, 2010 | 08:40 PM
ROG100's Avatar
ROG100
Basic Sponsor
Dave,
Put all the studs in so that the amount of threads remaining allow for the gasket, oil pan and lock nut plus about 3 threads. Use blue loctite after you have cleaned all the holes & studs with brake cleaner.
The surface of the gasket and oil pan should be clean and grease free and use no sealant.
DO NOT overtighten the gasket - if it bulges at all that is to much.
Two fingers pressure on the end of a 10mm wrench is about right.
Roger
Old Jul 5, 2010 | 08:46 PM
davek9's Avatar
davek9
Exactly what Roger said.!
Note: some of the holes go straight through, so set the length/depth of the studs by bottoming out the ones that don’t, then make them all the same.
DaveK9
Old Jul 5, 2010 | 09:06 PM
ROG100's Avatar
ROG100
Basic Sponsor
Listen to what DaveK9 says as he has done it more times than I 8>)
Old Jul 5, 2010 | 10:48 PM
aaddpp's Avatar
aaddpp
Roger, Dave
Much appreciated. On my way to putting everthing back together.
Dave
