The Good Life...
Orbiter.
are you planning to go to Porshces to Oxford 7/31. Oxford OH? you should. we can park our ruby red metallic/camel 928s next to each other.
several of the central OH and some KY 928 owners will be there.
Needs some paint work as I recall... It would easily cost more than Ruby to get to the condition of Ruby... That is always the problem for buyers...no worries. it is what it is.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
I will try to make it! Thanks for the heads up!
You're going ona beer run? ...well then you might also want to post where you live. I may be right over. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I did something similar yesterday. Ditched work early, went home and pulled Perl out for the garage, and went cruisin' to find a car seat. Any excuse is a good excuse.
Ahh... it IS the good life, the power, the handling, the style. The GT has been pressed back into daily driver mode and it's a blast driving back and forth to work everyday! Even in Phoenix, it was 113 deg. Wednesday and 114 deg. yesterday and no issues with the 928. A/C works great, even after the car is heat soaked for awhile. Those of you that think the 928's A/C system is inadequate, you have something wrong with your system. If it can work well in this Phoenix heat, it should work well anywhere!
My AC is blowing so cold I can't believe it. We have both heat and humidity here in Iowa and it handles them both. Now, when I was in Mississippi a month ago and it was two rats in a wool sock hot and felt like I was underwater, the system was blowing fog on me. Just too dang much water in the air.
