trans swap??
2. You can also swap in an LSD (from another auto or manual of the same pre/post '85 type)
I'm doing it at the moment. You will need a crazy strong 2-jaw bearing puller to do the swap (diff bearings are a f*&^%r to remove), and be comfortable following the workshop manual to measure and re-shim for bearing preload and backlash.
Its actually not that hard.. if you do your own intake refresh and TBWP then this shouldn't hold much fear - I'll be doing a write-up when the car's back on the road.. got many pics so far.
