928 Forum 1978-1995
Sponsored by: 928 Specialists
Some suspension plans for you to tear apart
Old 07-02-2010, 06:45 AM
  #121
ptuomov
ptuomov's Avatar
Default J9/18/et68 fronts and 11J/18/et54 rears
Will a set of CCW C14's in sizes J9/18/et68 front and 11J/18/et54 rear fit on a S4? The rubber is AD08 255/35/18 and 295/30/18.
Below is the rear tire info:
Old 07-02-2010, 09:06 AM
  #122
tv
tv's Avatar
Nice tread pattern. I have seen some other tires on occassion in some tire stores that had even more funky patterns, like wavy lines and almost approaching a slick because not a lot of tread, those are cool.
New avatar got a bigger pic?
Old 07-02-2010, 09:47 AM
  #123
ptuomov
ptuomov's Avatar
Put some here:
https://rennlist.com/forums/928-foru...y-out-289.html
Comments (with pictures) welcome in that thread.
Old 07-02-2010, 11:10 AM
  #124
tv
tv's Avatar
Great, that blue is just the right color and looks factory.
Old 07-02-2010, 11:49 AM
  #125
Frank Castle
Frank Castle's Avatar
Attachment 456348
Andrew's 928 Wheel Fitment Calculator indicates that you would need a 5mm spacer on rear hubs to prevent tire from rubbing on inside. Can anyone else verify?
Old 07-02-2010, 12:32 PM
  #126
ptuomov
ptuomov's Avatar
That concerns me a bit, and that's why I am asking. A lot of people are running wheels with 8" backspacing. This would have 8.125" backspacing. Will that work? The CCW rep said that with 295 tire, 928 can run with as much as (or as little inside clearance as) 8.25" backspacing. The landsharks fitment doc has an example of someone running 295/30/18 on 11J/18/et54 in the rear without any problems.
Any first hand experiences or links to first hand experiences would be greatly appreciated.
Last edited by ptuomov; 07-02-2010 at 02:07 PM. Reason: typo in the number and error in the phrasing
Old 07-02-2010, 12:41 PM
  #127
Frank Castle
Hopefully some members will give some feedback as this is the next big purchase for my 928. Let us know what you find out.
Old 07-05-2010, 12:59 PM
  #128
tv
tv's Avatar
Old 07-05-2010, 03:00 PM
  #129
dr bob
Chronic Tool Dropper
dr bob's Avatar
Tuomo--
That combo -may- fit, depending on the actual shape of those tires. I've seen the same sized tires from two different manufacturers have almost half an inch difference in cross section. That translates into 1/4" difference on either side of the tire. enough to maybe eliminate the 5mm spacer need.
Old 07-05-2010, 03:20 PM
  #130
ptuomov
ptuomov's Avatar
On a 10.5" wheel, the section width of 295/30 ad08 is 11.7" and the tread width is 11.5". On the same size wheel, the section width of 295/30 Bridgestone RE050A Pole Position is 11.9" and the tread width is 11.6". The 295/35 Bridgestone RE050A on a 10.5" inch whee has section width of 12" and tread width of 11.8". All three tires can be run on a 11" wheel, in which case the section width of all three tries grows by about 0.25".
Does this information help in coming up with the answer? Can you share some data on what tires have rubbed on 11" wheels and what offset did those wheels have?
Originally Posted by dr bob
Tuomo--
Old 08-13-2010, 04:39 PM
  #131
tv
tv's Avatar
something to read;
The Boss is back: Iconic Ford Mustang reborn
This Boss 302 is the first non-SVT model to pull more than 1 g of lateral acceleration. On road courses, the Boss is said to better the GT's lap times by two seconds. The Boss 302 is also enhanced with a list of performance upgrades to the steering and chassis. It's lowered 11 millimeters front and 1 millimeter rear compared with the GT and gets adjustable shocks and struts. There also are stiffer suspension bushings, high-rate springs and a larger rear stabilizer bar. The Boss rolls on black 19-inch alloy racing wheels wrapped in Pirelli PZero rubber.
Read more: http://www.autoweek.com/article/2010...#ixzz0wW4tqZXi
The mustang has a higher center of gravity and I doubt it is close to our 50/50 balance yet they have put in the necessary suspension pieces MAINLY shocks/springs to get it to stick. The 928 should do better with equivalent pieces and rubber.
Quick Reply: Some suspension plans for you to tear apart
