928 Forum 1978-1995
Sponsored by: 928 Specialists
Volvo Engine Mounts from Roger - Excellent
Old Jun 23, 2010 | 04:26 PM
c_span's Avatar
c_span
Originally Posted by blown 87
It is doubtful you will ever see a running vintage Volvo with a V6, it may not be the worst automotive engine ever made, but it will be in the top ten.
Is that the "legendary" PRV v6 engine?
Old Jun 23, 2010 | 04:30 PM
6.0-928S's Avatar
6.0-928S
Originally Posted by dr bob
Was that the "pooled resources" V6, with Renault and Alfa? Am I thinking about the right mfrs at all?
Peugeot. Same as the DeLorean.
Hammer
Old Jun 23, 2010 | 04:33 PM
blown 87's Avatar
blown 87
Rest in Peace
The Infamous Peugeot POS-V6, the one they used in the Delorean, yep one and the same, some European RV builder used them in motor homes, did not work out well for them either.
Could not keep cams in them was the biggest problem.
Old Jun 23, 2010 | 04:35 PM
blown 87's Avatar
blown 87
Rest in Peace
Originally Posted by jeff spahn
What kept you from junking the last one to keep them from reproducing?
We are in the South, the owner took it home for machine gun practice.
Old Jun 23, 2010 | 04:43 PM
6.0-928S's Avatar
6.0-928S
At the dealer we would cut a hole in the firewall to replace the cams, fastest & easiest way.
Hammer
Old Jun 23, 2010 | 05:08 PM
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Originally Posted by ROG100
740, 760, 780 & 940
Don't they also use the Bosch LH? I'm starting to see a pattern here...
Old Jun 23, 2010 | 06:09 PM
Stromius's Avatar
Stromius
I am about the put the Anchor's I got last summer (pre issue batch) in my car tonight. Should I not and get the Volvo's????
Old Jun 23, 2010 | 09:00 PM
Brad W's Avatar
Brad W
Drill a hole in them and see if they a fluid filled. Then you will know for sure.
Old Jun 23, 2010 | 11:14 PM
Dan87951's Avatar
Dan87951
A service I gotta do on my daily. Been putting it off for to long, maybe that was wise to see how these volvo mounts hold up. Are these solid?
Old Jun 24, 2010 | 09:03 AM
Brad W's Avatar
Brad W
From what I understand the Volvo mounts are fluid filled. Same quality as the Porsche mounts just cheaper.
Old Jun 24, 2010 | 09:18 AM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Oh dear lord, one of the worst automotive engines in one of the worst automobiles ever made.
I guess a nose full of blow will give you great ideas like this
Old Jun 24, 2010 | 09:20 AM
ROG100's Avatar
ROG100
Basic Sponsor
At this point refrain from drilling a hole in the Anchor MM's.
First shake them next to your ear. If there is water sloshing around in them they are hydraulic.
Probably good to use.
If they do not slosh then squish them in a vice and see if they collapse easily - you will know if they are good or bad.
Old Jun 24, 2010 | 11:33 AM
Stromius's Avatar
Stromius
Thanks Roger! They pass those tests so I'm good Sorry for the OT question.
