17" Fikse Rims
Is anyone running a similar size/offset wheel on their 928? What size tires are you using?
17” x 8.5”
5x130 bolt pattern
7” inner half/1.5” outer half
6.75 backspacing (~50.8mm offset)
20.05lbs.
2 rear wheels and the specs are:
17”x11”
5x130 bolt pattern
9” inner half/2” outer half
8.625 backspacing (~66.6mm offset)
20.68lbs.
17” x 8.5”
5x130 bolt pattern
20.05lbs.
17”x11”
5x130 bolt pattern
20.68lbs.
You really should not go below ET55 in front, if possible.
Check this link:
http://www.landsharkoz.com/forms/928wheels.pdf
Check this link:
17” x 8.5”
5x130 bolt pattern
20.05lbs.
17”x11”
5x130 bolt pattern
20.68lbs.
17” x 8.5”
5x130 bolt pattern
20.05lbs.
17”x11”
5x130 bolt pattern
20.68lbs.
Alex, you are right about keeping above 55mm on the front offset if possible. In my case w/ stock ride height I have had no problems at all w/ these, but they do stick out a touch so a REALLY big pot hole would ruin my day!
