928 Forum 1978-1995
Sponsored by: 928 Specialists
Whistling noise from engine
Old 12-12-2019, 03:03 AM
Bruno Kuzmin
7th Gear
Bruno Kuzmin's Avatar
Cool
Originally Posted by Tomkat80222
Does it start whistling if you allow the car to just idle? Or does it happen, like in the video, after you increased the RPM's?
Yes, always when the engine is not completely cold.
I will try to find the reason soon. Thanks for ideas. I will report about results soon.
Old 01-04-2020, 10:37 AM
Bruno Kuzmin
7th Gear
No result so far. I changed for a new one rubber coupler between the intake tubes and the central collector and checked all small rubber couplers. They are all OK. I also changed for a new one auxiliary air valve.
It is also interesting that whistling sound is not present at the start of cold engine. It starts after 20 to 60 seconds. It sounds like that some kind of valve opens and then engine starts whistling. What could that be???
Old 04-12-2020, 04:33 AM
Bruno Kuzmin
7th Gear
I made it. Problem was with gasket between engine block and intake manifold.
928 DesMoines (04-12-2020)
Old 04-12-2020, 05:15 PM
928NOOBIE
928NOOBIE's Avatar
Your air filter is in upside down in the pic of the engine in your first vid.
Old 04-13-2020, 05:21 AM
Bruno Kuzmin
7th Gear
Quick Reply: Whistling noise from engine
