I need an antenna, must be able to be mounted with no holes in body
#31
Would it be possible to just install a radio amplifier
without an antenna? I would guess the mounting location where the actual antenna connects would be enough to support the signal with the amplifier. Just a thought.
jpc
jpc
#35
Wally i took your advice and got a wire about as long as you suggested except that since the antenna connection point was still on the outside of the windshield i just attached the wire to the pin.
This was then routed around the outside edge of the windshield and i cut some black elex tape and taped it to the windshield.
First i removed all of the trims so to get the wire as close to the edge of the window as possible, its pretty hard to tell its even on the window and the radio is now pulling in FM signals .
Thanks for your suggestion,Stan
#36
Something like this?
Hidden antenna
Hidden antenna
