new mm report
#46
Basic Sponsor
My price for the Porsche MM is $259 each
#47
Cars without a torque tube apply the engine torque to the motor and I guess the transmission and rear end mounts (force on the rear end equal and opposite to force on motor mounts). 928 MM only needs to manage the engine vibration and torque from speed changes in the internal rotating assembly (TT cancels the driveline/wheel torque).
Which has me wondering how much the transmission moves and what kind of forces are on the transmission mounts?
#48
They may be a perfect alternative, but all of my alarm bells are going off. We're talking about a product designed for a very different application with what, a week's testing? Hello??
Just my $0.02 ...
Jim & Sue Corenman
Just my $0.02 ...
Jim & Sue Corenman
After getting no support from the manufacturer Roger, to his credit, found a replacement. Also to his credit he warranted the failed mounts with free replacements and in Jeff's case free replacement labor.
The best replacement happened to also be hydraulic. The weight of the original application is very close to the 928 application so they should work fine. They are both hydraulic, they both will most likely fail over a period of years. Just like the first Ford MM's only time will tell if this is a good substitute, but if no one is willing to try we will never know. So it comes down to; Do you want to spend $500.00 for two mounts from Porsche or $92.00 for Roger's mounts.
I intend to save the $408.00 for something else. YMMV
#49
To edit Roger's post above the Volvo mount is on top and the Porsche mount is below.
#50
Interesting. Looks like the Volvo unit is a bit taller, but look at the seams, they have much better overlap than the factory part.
I am game to give them a try. Will get a set in the next order, and report my findings. May be a while though, going to try spending some quality time with the AMG next.
#52
What method do you use to change out the mounts in an afternoon. Is that process already documented on rennlist somewhere?
I am sure my 1979 needs them as every other rubber bushing I have looked at is shot!
#53
just put the car on a lift, get three guys and you can do it in two hours.
#54
Shameful Thread Killer
Very true doc. You gotta lay out some prime beef and chops or nada getting done. Feed those that help or you will burn for eternity
#58
JWillman,
'79 model 928's have a complete different MM (unless you or the PO have changed them out) Yours should be a big square block of rubber mounted in a steel cradle. They DO go bad, but the typical repair (from what I've heard) involves drilling a hole and using a long bolt and nut, and not replacement.
#59
http://members.rennlist.com/sharkski...ine_Mounts.htm
Try this, Sharkskin's pages for the 79. This is his "RND 25".
It is possible, I've read somewhere, to retrofit newer mounts onto older cars. I think you need the crossmember from a later car.
#60
The locating pin on the Volvo mount looks smaller than on the OEM. It's probably a trivial difference but does this make much difference to install procedure, and are there any issues regarding precise location of the pin (seem to remember with the Anchor mounts pin had to be cut off).
Not changed mounts before but will diy the set due on my car, so forgive naive question!
