heater control valve was installed backwards
There's more than one metal valve. One of them looks almost identical to the Porsche plastic one. There is another that is all metal that does not have an external arm. I put this one into my wife's 968 4 years ago and it is still fine. I got it at NAPA.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I wasn't able to find anything in stock at NAPA with 3/4" hose inlet. Plastic or metal. They show a metal unit for an Audi 100 (BK 6601410), but it seems to be out of stock throughout the NAPA network.
I have a metal one coming to me from AutoZone. It crosses with a '91 Audi 100. Everco 74671 . It's $20 delivered, so I'll see how it holds up.
Weird. Same p/n as the Autozone unit, but completely different valve. It's identical in appearance to the out-of-stock NAPA "Balkamp" that crosses for an Audi 100.
Both have the necessary 3/4" inlets. On the 944 board I read a post about one of our oem plastic valves opening up on the track and laying down a slick of coolant for the next guy. Metal seems like the way to go here...
....unless you don't mind the possibility of this happening:
![](http://home.comcast.net/~jsnord/pics/heater_valve.jpg)
OP, if you're still contemplating a replacement valve, I'd jump on this one from Rock Auto. This appears to be the same unit as the one at NAPA & other parts houses that apparently is out of production (why? that's a good question).
But for $11 plus shipping for a metal valve, you can't go wrong IMO. If you're more comfortable with the oem part, 928 Specialists has them..but considering the reported failure rate of the plastic ones, I'd keep a metal one around as a backup.
Rennlist Site Sponsor
A word of warning - many, if not most, vacuum-operated heater valves open when vacuum is applied. The 928 valve closes when vacuum is applied...
