Delco Alternator Strange Behavior
#31
Location: Magnolia TX, just north of Houston, Red 1984 S
one with extremely worn slip rings, pictured previously in this thread
none of the 4 had brushes replaced. All were worn to apparently 1/2 original length or less. I did order 1 new replacement regulator with brushes just to see if that solves any problems, have not yet received those. Should be interesting, but won't prove anything.
one has a very noisy bearing (front)
the one from fleabay that drops to 11 vdc with the car headlights on and running at 2000 rpms had no key in the keyway when received, suggesting very sloppy work. I also suspect a bad diode on this one but have not yet verified what is wrong.
Not exactly a sterling recommendation for "rebuilts" from multiple sources.
#32
tmpusfugit,
Did you get your ebay alt from these guys?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
I got mine from them, and it was missing the key, too. It took me two hours to file down my other one to fit the new one. The bearing is a little noisy, but it seems to be working okay so far, as long as I've got the idle set right.
The alt I took out is a Valeo, and I wonder if I should rebuild it for next time. It's actually designed for the cooling shroud whereas the new one isn't, though it's a Bosch.
#33
tmpusfugit,
#34
Cool. They did not do a very good job with mine, though it was a great price. You get what you pay for, but I'm happy I got it working. My voltage issues are gone.
Though I do wonder about replacing the field wire completely. It does not feel healthy at the alt end.
#35
tmpusfugit,
to be precise...and I have the same problem with the cooling shroud too....I have 2 shrouds, one new (later) style and one earlier, and neither fit...
#36
Yep, these are the folks from where the fleabay alternator came from... http://cgi.ebay.com/ebaymotors/ws/eB...4877&viewitem=
#37
Just a thought, but the original shroud system was to 1) deliver fresh air to the alternator and 2) keep out dirt/grit/road debris and the like...just forcing air on it might put even more dirt into it....would it not?
#39
Chronic Tool Dropper
The airflow through the alternator is rear-to-front, with the front fan a radial-discharge type. 'Scooping' air and junk into the front won't help at all with internal cooling.
Check with Mark or Tom at 928 Int'l for their info on their rebuilder. It isn't too hard to see that paying some extra up front for a known-reliable rebuilt, from a known-reliable supplier with a serious community reputation to maintain, that happens to be an exact fit including the cooling shroud attachment, is a better deal than two or three questionable but cheaper units that don't exactly fit with the cooling shroud and come sans Woodruff key. As much as I love laying under the car with the pans off, finessing the alternator into place and getting everything attached again, I love even more that I only needed to do it once, and it worked perfectly once installed. I put all the belly pans back on before I bothered to start the car and look at the voltage readings. I'm not sure I'd be that confident with a junk-yard spray-cleaner 'rebuilt' unit. The 'lowest-cost' unit is not necessarily the cheapest in the end, and it sounds like it may not be the 'best value' either.
#40
#42
You are exactly right. No argument here.
But I've got my el cheapo alt working great, and I'm going to leave it on there until I can get my Valeo rebuilt for standby.
Right now I've got a bigger issue: one failed brake circuit. I can actually feel less braking power, and this coincides exactly with when the light came on yesterday. Am I correct in thinking that the master cylinder is like two brake systems in one? Two cylinders providing pressure that ultimately meet up in one line at the wheel with a check valve up stream to prevent one side's pressure from entering the other cylinder should it fail?
If I'm right, I need to replace the master cylinder. I know most people have been able to just change out the switches and were good to go, but I've actually lost braking power.
So the el cheapo alt can stay where it is for now.
I'm glad I was able to get a functional Central Warning unit ($30 off eBay).
#43
Sharkskin tried to shroud a higher-output Delco.
Check his round 21
http://members.rennlist.com/sharkski...Alternator.htm
