transmission fluid feedline banjo bolt torque
Folks; search through the manuals that I might, I can't find a torque value for the banjo bolts that connect the transmission cooler lines to the transmission body. I'd like to finish the line reinstall today, if you can provide that information. Thanks!
Can't find it either, but I think those bolts are M14 x 1.5, which is the same size as the banjo bolt on the power steering high pressure side. That one is torqued at 30 Nm. At least something to go on. Torque down with feeling and if something doesn't feel right, stop. Proceed at own risk
