GTS vs S4 crankshaft
http://www.ret-monitor.com/articles/...rankshafts.pdf
By the way, those pics are awesome.
If you can't see the pics on the webpage, you can download the article in pdf format here:
That S4 crank pic w/ the nice depth of field was taken w/ Jim's 18-200 VR lens. Also that crank isn't stock. It was drilled by Jay @ Taylor Engine.
The center main journal hole gives a hint that something not entirely stock is going on with the crank.
The pdf article and the html page are quite different. The pdf, for example, doesn't have any mention of 6 vs. 8 cw crankshafts.
In any case, just killing time wondering if there's a decent crank hiding inside either one of these...
I am not an engineer, I was merely relaying info I got from other people who are engineers and build engines...
If the 8 wt design is worse, why did Porsche do it & why do SO many modern race engines use it...the 8400rpm M3 uses 8 weights & makes 103.5 HP/L
http://www.rcollins.org/m3/RS46/DSC02293.jpg
It is interesting that the LS7 uses a 6 weight design....but turns "only" 7000rpm, even thought the far longer stroke moves the pistons over 10% faster than the M3
![](http://www.rcollins.org/m3/RS46/DSC02293.jpg)
928, advantages, counterweighted, crankshaft, engine, fully, gts, inertia, krankshaft, momentum, piston, s4, summing, total, v8
