Ball joint spins when tightening nut
I am trying to reconnect the Upper Control Arm to the Steering knuckle but the ball joint keeps spinning with the nut.
Anyone have a good trick for this? I searched and came up with:
1. Impact wrench.
2. Jack up lower control arm
3. Use a lever to push down on the UCA
I tried 2 & 3, and don't have an impact wrench.
So, whatcha got?
TIA,
1. Impact wrench.
So, whatcha got?
TIA,
Take a center punch and dimple the ball joint shaft in 3 secion evenly spaced around the slightly raised shaft surface will than bind when inserted.
Good luck
Good luck
I think he is, making the tapered shaft ruff, you could also use some brake clean in the surface(s) to be sure there is no grease.
I have had luck just using pressure to jam the two together, jacking up the lower and pulling down the upper, maybe a ratchet strap?
Got it.
Dave, I had the lower jacked up and was giving it all I had with a breaker and a cheater as a lever on the upper, but the little f***er just kept spinning. Granted it was 2am and I may not have been at full strength either.
I'll degrease, scuff it up and try leverage again tonight.
Thanks guys.
Thanks guys.
Old thread, but relevant. Jack up the lower control arm to establish the correct position and the lever down the upper control arm to engage taper. Works!
Any thoughts on torque values for the upper and lower ball joint nuts?
Just put a big c-clamp on the arm and knuckle and squeeze them together. Once the nut passes the 'magic point' the taper will be seated and then you can easily tighten the rest of the way.
Archive Gatekeeper
Here's a cheat sheet I put together a while back, AO made it pretty and useful. Needs to be updated but should work for the basics for now:
https://webfiles.uci.edu/redwards/pu...r%203-3-10.xls
